Hi experts!
I am trying to automate few simulations with different inputs. I am trying to do with a geometry from de tutorial: "Mixing Elbow". This geometry has two velocity inlets that i want to change in each simulation. My excel table is something like this:
ID | VEL_LONG | VEL_SMALL |
412 | 0.4 | 1.2 |
512 | 0.5 | 1.2 |
612 | 0.6 | 1.2 |
413 | 0.4 | 1.3 |
414 | 0.4 | 1.4 |
415 | 0.4 | 1.5 |
513 | 0.5 | 1.3 |
614 | 0.6 | 1.4 |
I have made a visual basic Script that doesn't give any problem. My problem is with the .bat because i dont know how to link my script.bat with the file mixingElbow.inp in order to get the simulations with the velocity inlets changed
In the mixingElbow.inp I have this for both, the small and the large one
SIMPLE_BOUNDARY_CONDITION( "Small_Inlet" ) {
surface_sets = { "mixingElbow.SurfaceSet_3.tria3.SolidBody_2_1.tet4" }
type = inflow
inflow_type = average_velocity
precedence = 1
average_velocity = Env( "V_Small")
And for the script.bat i have this:
@echo off
SETLOCAL ENABLEDELAYEDEXPANSION
set input_file="C:\Users\Stress\Desktop\rosa\AUTOMATIZ\MIXING_ELBOW\velocidades.txt"
set base_dir="C:\Users\Stress\Desktop\rosa\AUTOMATIZ\MIXING_ELBOW"
for /F "usebackq tokens=1,2,3 delims=," %%I in (%input_file%) do (
set "ID=%%I"
set "V_Large= %%J"
set "V_Small=%%K"
echo Leyendo ID: %%I - Velocidad Grande: %%J - Velocidad Pequeña: %%K
REM Crea la carpeta para el identificador si no existe
echo Creando carpeta: ID_%%I
if not exist "ID_%%I" (
mkdir "ID_%%I"
echo Carpeta ID_%%I creada.
) else (
echo La carpeta ID_%%I ya existe. Saltando creación.
REM Cambia al directorio de la carpeta creada
pushd "ID_%%I"
REM Copia el archivo ACU-T1000_Manifold a la carpeta que se acaba de crear
copy %base_dir%\mixingElbow.inp . > nul
if errorlevel 1 (
echo Error al copiar mixingElbow.inp
) else (
echo Archivo mixingElbow.inp copiado correctamente.
REM Copia la carpeta MESH.DIR a la carpeta que se acaba de crear
xcopy %base_dir%\MESH.DIR .\MESH.DIR /E /I /Y > nul
if errorlevel 1 (
echo Error al copiar la carpeta MESH.DIR
) else (
echo Carpeta MESH.DIR copiada correctamente.
REM Vuelve al directorio anterior
popd
ENDLOCAL
