Hi experts!
I am trying to convert the results that HyperMesh gave me to the ensight format or .x3d. I have seen that ther is a tool to make it called 'acuTrans' that is to translate the AcuSolve solution output to other formats and I have put on AcuSolve this line acuTrans -pb ACU-T1000_Manifold.1.Log -to ensight but it gave me this problem :
acuTrans: *** ASSERTION in Function <trnProc> File <trn.c> Line <251>
acuTrans: *** problem ACU-T1000_Manifold.1.Log not found
I don't know if the problem is with the syntaxis or is because is not the way to transform these files.
Thank you so much
