I've been using the Edem API Tutorial 6 to get a feeling for custom factories. So far I have:
- adjusted the code to create particles every 0.2 seconds at a fixed location on the table
- with a Z-Velocity of 1.0 (gravity off)
- adjusted code is attached below
I am now rotating the table (could be any other geometry) along the X-axis and I want the particles to reference the rotating Z-Axis of the table and spawn along that Z-direction. The Particle are spawning along the local/global? Z-Axis currently (see attached image)
It would be very useful if someone could name some API/Classes/Methods in the documentation to look for. Or any other suggestions to handle this problem.
Some ideas of mine:
- Reference the coordinates of the table with some getMethod()? or the initial velocity of the rotation with getVelocity()?
- Calculate the normal to a rotating object, and set the direction of the velocity of the particles to that normal
I appreciate all suggestions.
Semih
.jpg)
// Calculate number of iteration int numIteration = 0; // spawn a particle every after time double timerStep = 0.0; // [s] NApi::ECalculateResult CSnooker::createParticle( double time, double timestep, bool& particleCreated, bool& additionalParticleRequired, char type[NApi::API_BASIC_STRING_LENGTH], double& scale, double& posX, double& posY, double& posZ, double& velX, double& velY, double& velZ, double& angVelX, double& angVelY, double& angVelZ, double orientation[9], NApiCore::ICustomPropertyDataApi_1_0* propData, NApiCore::ICustomPropertyDataApi_1_0* simData) { if (time > 9 || m_numberCreated >= 100) { particleCreated = false; additionalParticleRequired = false; return eSuccess; } if (timerStep - time < 1e-04) { // Mark that we are creating a particle particleCreated = true; // Set some fixed values for all particles we create velX = 0.0; velY = 0.0; velZ = 0.0; angVelX = 0.0; angVelY = 0.0; angVelZ = 0.0; for (unsigned int i = 0; i < 9; i++) { orientation[i] = 0.0; } scale = 1.0; // Z position is the same for all aprticles (just above the table // X and Y vary posZ = 0.025; strncpy(type, "red", API_BASIC_STRING_LENGTH); posZ = 0.1; posX = 1; posY = 0.5; velZ = 1.0; // Mark the particle as created m_numberCreated++; timerStep += 0.2; // We are creating 21 particles, if we've done them all // then no more are required additionalParticleRequired = (100 != m_numberCreated); return eSuccess; } else { // timerStep += 0.1; } // Count the number of iteration numIteration++; }
