I found the below link to a morphing question, but the link in the answer does not work.
https://community.altair.com/community?id=community_question&sys_id=b1b604ba1b2bd0908017dc61ec4bcb13&view_source=searchResult
How can I morph mesh on a surface and automatically update the surfaces associated with the morphed mesh?
Thank you,
https://2021.help.altair.com/2021/hwdesktop/hm/topics/tutorials/hm/hm_3600_morphing_tube_to_different_configurations_c.htm?zoom_highlightsub=hm-3600
Does that link work?
If you are trying to associate the mesh to the surface then the projection option should work.
Hi Ben,
The link works, but I can not find the hm.zip or tube.hm file in the installation directory to run through the example. Any idea where teh example file is located in 2021.2 install?
Casper
