What is the fastest way in deleting loads in sframe? I normally applied negative value to the existing positive value to make it zero. Is there a way to just delete the load?
Hello, Iemuel,
Thank you for reaching out to us. You can delete your loads in S-FRAME easily by selecting the load tool of the load you want to erase, and holding the Control (Ctrl) button and the click, drawing a dashed, red box, with the said loads inside the box.
Keep in mind the loads erased depend on the selected load case and the load tool activated.
Alejandro Lopez
Altair Support
Hello, Iemuel, Thank you for reaching out to us. You can delete your loads in S-FRAME easily by selecting the load tool of the load you want to erase, and holding the Control (Ctrl) button and the click, drawing a dashed, red box, with the said loads inside the box. Keep in mind the loads erased depend on the selected load case and the load tool activated. Regards, Alejandro Lopez Altair Support
Further to this, we have a video that describes this workflow, and near the end describes deleting loads: https://www.youtube.com/watch?v=14D7eLGYshY
Regards,Matthew Sauer
