Is it solved? Can ask you a question? What is the reason for flashback when connecting to abaqus when doing joint simulation?
We have verified with the latest versions of EDEM+ Abaqus it works well.
request you to follow the below specified tutorial before going to the main problem
Product Documentation - EDEM-Abaqus Coupling User Guide (altair.com)
In the above link there is a pdf document , EDEM setup files ,cad file , inp and CAE file.
in the pdf document procedure is explained in detail, if you go through you will understand that which step is missed in your simulation file.
Thanks,
Prasad A
Hi, We have verified with the latest versions of EDEM+ Abaqus it works well. request you to follow the below specified tutorial before going to the main problem Product Documentation - EDEM-Abaqus Coupling User Guide (altair.com) In the above link there is a pdf document , EDEM setup files ,cad file , inp and CAE file. in the pdf document procedure is explained in detail, if you go through you will understand that which step is missed in your simulation file. Thanks, Prasad A
Hello Prasad,
Thank you for your assistance.
Unfortunately, I am unable to access the "Product Documentation - EDEM-Abaqus Coupling User Guide (altair.com)" on the Altair website, even after logging into my account.
Could you please provide further guidance on how I can obtain this manual?
Your prompt assistance would be greatly appreciated as it is crucial for the successful completion of my simulation tasks.
Best regards,
NL
Indeed, I cannot open the document after log in.
