The structure has parts as hinges. There are rectangles with 5 carbon fibre tubes (unidirectional), attached in a row at the edges.
Besides, inside them, it has a larger aluminium tube, in the tubes without clearance. At the ends of the larger tube, it has a head like a screw and the other,
the screw thread.
So, how do I represent this model? 'pbeam' for larger tube and rb2 at the ends? so how can i represent without loopholes between carbon fibre tubes and larger tube?
furthermore, Can I connect the mesh from carbon's tubes and rectangle face?
