How to calculate INDUCTANCE COMPUTATION for 10 pole periodic machine.
Pradeep Shankar_22370
Pradeep Shankar_22370 New Altair Community Member
edited December 2022 in Community Q&A
How to calculate INDUCTANCE COMPUTATION for 5 pole periodic machine.
i tried using CreateLookUpTableFromTMProjectDQLight.PFM macro but there is an Exception('Represented pole pairs must be integer or 0.5',) error
how to rectify it and is there any other ways to calculate Id and Iq values at a specific speed point in 2d?
Thanks
Pradeep Shankar
Welcome!
  • Mohammed Elamin_22169
    Mohammed Elamin_22169 New Altair Community Member
    edited February 2022
    Hi Pradeep,
    Do you mean the machine has a total of 5 poles or 5 poles pairs? It is uncommon to have odd number of poles on electric machine. What you need to enter on this macro is the number of pole pair represented on the geometry of the model (for example if you modeling 1 pole in the model you would use 0.5).
    Otherwise, you can check the attached document which explain the procedure/steps you need to compute dq inductances.
    Thanks,
  • Pradeep Shankar_22370
    Hi Pradeep,
    Thanks,
    Hi Mohammed Elamin,
    There are 10 poles in a machine (5 pole pairs), I'm simulating periodic model it has 5 pole, so i taken number of pole pair represented on the geometry as 2.5 (0.5 for 1 poles)
    Thanks
    Hi Mohammed Elamin,
    Thanks
    Hi Pradeep,
    Okay, I see. Unfortunately this a limitation on this macro and it is excepted to be removed on the next version of Flux expected on April.
    If possible try to model an even number of poles or just one. If not you can refer to the document I shared and works everything from scratch.
    Thanks,
  • Ramon Perez
    Ramon Perez Altair Community Member
    edited April 2022
    Hi Pradeep,
    Thanks,
    Hello Mohammed Elamin
    The document that you have shared will be of great reference to me. Did I want to ask you if maybe you have chapter 6 and chapter 7 of the series of these documents? Chapter 6 "Eccentricity analysis", Chapter 7 "Effect of demagnetization on permanent magnets". If you have them, could you share them with me? These documents will serve as a reference for a research project that I am developing.
    Thank you very much
    Ramón
    edited August 2022
    Hi Mohammed Elamin,
    Whether the limitation on this macro got removed?
    I tried in 2022 and facing the same issue.
    Thanks
    edited August 2022
    Hi Mohammed Elamin,
    Thanks
    Let me check if the limitation still exists on the latest version Flux 2022.1. I will get back to you.
  • Karun Avula
    Karun Avula
    edited August 2022
    Hi Mohammed Elamin,
    Thanks
    Hi Pradeep,
    The limitation is there for 2022.1 version as well. We will check with dev team and get back to you.
    Thanks and regards
    Karun Teja
  • Hallay
    Hallay Altair Community Member
    Hi Pradeep,
    Thanks,
    Hi Mohammed Elamin
    Do you have below Flux file?
    If you have, can you share it?
    thank you
    Hallay said:
    Hi Mohammed Elamin
    thank you
    Hi Hallay,
    I attached the file here.
    Thanks,
  • Hallay
    Hi Hallay,
    Thanks,
    Thanks a lot.
Welcome!
Welcome!
