Hello everyone,
I am trying to run a frequency response simulation by considering the fluid effect, the product is a Degas Bottle.
When I try to run the frequency response simulation (Modal), should I active the MFluid card?
Let me know, thanks!
Hi
I believe you need to select the Mfluid card .
Regards
Thanks for your feedback, I think you answer is right, I compared the results with & without the Mfluid during the frequency response simulation, the response acceleration shows big difference, but based on the test result, the one with Mfluid is the right one.
Then a new question will be, the Mfluid card only can be used in one frequency response simulation, if I need run the simulation in 3 direction, how can I realize it?
