In MFLUID, can I use Tria6 in the WSURF 1? Or I need use the tria3?
WSURF1 is a set identification number.
Kindly find the help documents attached for your reference.
Thank You
Hi, WSURF1 is a set identification number. Kindly find the help documents attached for your reference. <?xml version="1.0" encoding="UTF-8"?> Thank You
Thanks for your feedback, I checked all these to simulate the fluid effect during modal analysis, but I just wanted to know whether the MFLUID supports the triad 6 element in the element set, can you tell me?
