I have been following the e-learning course for an introduction to motionview. The model is a four bar linkage system. I tried increasing the end time parameter in the default analysis setting to increasing simulation time. For example: default simulation time is 5 seconds, and I want to change it to 20 seconds. The changing the "end-time" parameter in the default analysis setting led to a result of a change simulation time is changed, but the frames repeats itself after 5 seconds. So I just get an anmimation of the model repeating itself after 5 seconds instead of a countinous simulation of 20 seconds. Is there a step I am missing?
