I need the name of the current model imported in the Hypermesh to identify the model's file directory. I have tried using [hm_info currentfile], but it did not produce the output as expected. Is there any command which could be similar to that of this and which does not require panel interaction such as [hm_info hmfilename]. Any inputs with respect to TCL and HM commands would be much appreciated.
Thanks in advance!
