I have two plates with a tie contact. I wanted to have sliding between both plates without making a nonlinear analysis
I saw that Tie contacts have the field DOF. Does the purple plate is going to slide in the x direction if I put DOF: 23? I was wondering if the DOF field restrict the movement of the nodes, and if you delete the number 1 in the DOF field, the plate now is now allowed to move in the x direction
