I am a Student User trying to follow the ACU-T: 1000 HyperWorks UI Introduction when I got to loading the .log file (Results) Also I could not find the directory for the .zip file in the tutorial and imported my own .step file both the log (results) file and step file are attached, any help is appreciated.
There's something with the way the student edition is packaged that prevents loading the .Log file. From the Solution ribbon, open the Convert tool, and convert the results to Ensight format. Then from the Post tool you should be able to open the .case file - AcuSolve (.case).
