Generating mesh for stl model vith complex geometry
Hello riecently I start to work in your programm HyperMesh, I enjoy it very mush, so many posobilities! 'Ngn vet inte vad han skall fästa blicken på', as we say.
And becouse I am in the 3d printing theme. (Frankly, for me it is almost art! /emoticons/default_rolleyes.gif' title=':rolleyes:' />) I really want to use your program for meshing some breathtaking geometries for my customers. They need some speciefic requirements in the main strength characteristics. Ussually I used Abaqus for this properties but for complex geometry it could be sometimes very tricky and I was recomended to use your program. Could you tell me how to mesh complex stl model in Hypermesh, please?
As I uderstood, reading your forum, first of all I need to do open stl: File > Import > File type > STL;
then I need to create a geometry from mesh: Geom > surfaces from FE (elems - all; feature edges; complexity 10) [sometimes Hyper writes that he failed to create some surfaces, wich is oddly];
And then I can`t create solid, Hyper writes created 0 solid elements and 0 nodes /emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
If STL has good-enough quality for FE mesh, you not need to create geometry (surface/solid), you work directly over STL.
0 -
