Hello Jeremiah,
Are you using DataPrep studio or Monarch Classic ?
In DataPrep studio:
if your column type is text based you can right click on the column and choose Replace function and choose Null option which will allow to convert to any text you want including 'NULL'. If it is a number column same operation will convert blank column to 0.00
You also can create a new calculated field based on that column that has null/blank values and convert it to zeros.
If it is a text field, you can create a new formula column with the following formula:
if(isblank([blank_column]),str(1/0),'')
where [blank_column] is the field you are testing for a blank value.
