Hypermesh CFD, how to increase the running time based on the last step?
I have already run 800 steps and want to increase the running time, how to do it?
You would define your new running parameters - time step size, number of time steps or final time, etc - in the Flow Ribbon Setup/Physics panel, the same as you did for the initial run.
Thank you so much.
