Tip: Unable to continue executing code.
Please attach the complete .Log file - and the input (.inp) file.
Does it also behave the same if you use the current release - 2023.1 version?
Without .inp and .Log file, it would be difficult to say what the root cause of this is. Kindly upload them.
Please attach the complete .Log file - and the input (.inp) file. Does it also behave the same if you use the current release - 2023.1 version?
Hello, thank you for your reply. File has been uploaded
Any update on files that were asked for?
This looks to be the model for the tutorial ACU-T: 6100 - is that correct?
I don't see anything in those files that explains the error. What is the full path to the problem directory (the directory where the input file resides)? Any spaces or 'special' characters in any of the directory names? Those can sometimes cause issues.Are you able to run other cases with no troubles?
