Please kind-hearted people can help me answer this question.
Hi xixihaha,
Depending on your objective rigid body particles can be modeled.
Can you please elaborate on the objective of your problem statement?
Thanks,
Prasad A
Hi xixihaha, Depending on your objective rigid body particles can be modeled. Can you please elaborate on the objective of your problem statement? Thanks, Prasad A
Thank you for your reply.
I want to use incompressible particles to generate bonds. I hope the particles are an ideal rigid body without elasticity, but the bonds are elastic. Is there any way or API available?
Thank you for your reply. I want to use incompressible particles to generate bonds. I hope the particles are an ideal rigid body without elasticity, but the bonds are elastic. Is there any way or API available?
Hi Xixihaha
You can Choose base model as a HM-no slip and additional model as bonded_v2 which serves your objective. You can go trhough the below API model and the same model is in in-built EDEM as well.
Altair Exchange - EDEM API - Contact Model Example: Updated Bond Model (example of customisation of bond model)\
Hi Xixihaha You can Choose base model as a HM-no slip and additional model as bonded_v2 which serves your objective. You can go trhough the below API model and the same model is in in-built EDEM as well. Altair Exchange - EDEM API - Contact Model Example: Updated Bond Model (example of customisation of bond model)\ Thanks, Prasad A
Thank you very much!Thank you very much!
Do you have the API for the LinearElasticBonding model?
Hi Xixihaha,
Please find the linear Elastic Bond Model.
Tutorials, How To, Troubleshooting - EDEM Tutorial 5: Linear Elastic Bonded Model (altair.com)
Hi Xixihaha, Please find the linear Elastic Bond Model. Tutorials, How To, Troubleshooting - EDEM Tutorial 5: Linear Elastic Bonded Model (altair.com) Thanks, Prasad A
Thank you very much.Do you have the code for the LinearElasticBonding model? I may need the src file to be modified.
