how do i request to let Optistruct automatically write a tabluar file after the analysis (non-linear quasi-static), for example column 1 displacemen of a certain node and column 2 SPCF of this certain node?
I dont want to do this with HyperView and export graph, because there are to many analysises so i want to do it automatically.
The PUNCH file format only writes the results of the last timestep and don`t allows SPCF in non-linear quasi-static.
The time history file T01 ist not available for non-linear quasis-static analysis either.
Thank you very much for your help!
With kind regards
Tim Winkler
