what does this error message means?
*** WARNING # 4961
Reference stiffness underlying contact 1 is 9.860277e-11 times
the average diagonal stiffness of the global model.
I have TIE, SMALL friction and FINITE friction surface-to-surface contacts in my model. For all of them this error message appears after changing geometry and mesh. In the same model with a slight other geometry and before remeshing, these errors didn't appear. All i did was reassign the contact surfaces to the new mesh.
Defining the contacts totaly new didn't helped.
Tank you very much for your help!
With kind regards
Tim Winkler
