要素、節点のリナンバを右下図のようにX軸でソートして行いたいのですが、(図では要素)可能でしょうか?
I can't read the characters but from the picture I think you are looking for spatial renumber. In the latest version it can be found in the Assembly ribbon and renumber can be changed to spatial renumber with the drop down in the bottom right corner of that ribbon item. In older versions I believe it is under the Aerospace menu.
That's the answer I was asking for.
Thank you very much!
