I have a relatively large bulky part with many internal holes. I need to view the stress field inside the structure and not on the outer surface.
I tried to use the 'Clip assembly with with a plane' but it doesn't work well. I don't see the cut-plane surface, only the outer surfaces.
I tried to search for this option in the documentation but I couldn't find anything.
Is it possible to do that in Simsolid?
Thank you,
Amir
