I have added for a trial run the -optiskip option to the Optistruct options under the Analysis panel. If I select run options: analysis, -optiskip keep appearing even if I delete it. It's not a big problem but sometimes I forget to remove it and realize that it was there just after the end of the run. Is there a way to have a blank options filed by default again?
Thanks in advance
