Good morning,
I am currently working on a frame model constituted by multiple thin-walled beams which are joined together. Since I need to vary several parameters in the model, among which the thickness of the different elements and their shape, I have modelled directly the CAD geometry as a surface geometry to avoid the mid-surfacing and the consequent cleanup procedure. My problem now is how to deal with the thickness changes. I would ideally design the standard external geometry and assign the shell thickness inwardly. In this way, I could easily change the thickness of the components without the need of changing the dimensions of the CAD surface geometry. In fact, with the normal shell elements assigning 1/2 thick upward and 1/2 downward if one beam is modelled with a surface section 100x100 mm with a shell thickness of 2 mm the represented beam will be 102x102 mm, and if I increase the thickness of the elements to 4 mm the represented beam will be 104x104 mm, which is not what I want to obtain since I would like to keep constant the external size of the represented cross-section.
Have you any advance on an efficient way to proceed?
Thanks in advance for your support
