I’m facing an issue with INRELL and SUPPORT
I will describe the issue with the following example:
Thrust force = 10 Lbs
Mass = 2
G = 5
Case 1 (Gravity LC):
I’m running a gravity case the applies 5Gs to a mass of 2 resulting in 10 Lbs thrust. For the gravity case I’m applying a BC as an SPC connected to a CBUSH (10^7 Stiffness all 6DOF). CBUSH has coincident nodes and the other node is tied to a RBE3 with dependent node at the center of a cylinder.
Case 2 (Thrust LC):
I run the same BC with a for applied a the other end of the cylinder (10 bs). The force result in equivalent force to the G and mass.
Results from Case 1 and 2 are similar.
Case 3 (Thrust LC, BC with SUPPORT and INRELL):
I run the same configuration as Case 2, but instead of a SPC I use SUPPORT connected to the CBUSH and INRELL -1.
When I compare results from Case 2 and 3, they are 10 times smaller for case 3.
I’m using the following PARAMs:
WTMASS
WTM_V1 = 0.00259
And the Gravity load is:
G: 386.1
N1: 5
Why this 1 fold difference in results?
