Continue Loads through subcases
User: "Arno Heidkamp"
Altair Community Member
Updated by Arno Heidkamp
I want to do a non-linear analysis with subsequent loading:
  • Subcase 1
    • Prestress
  • Subcase 2
    • cont. Prestress
    • Load 1
  • Subcase 3
    • cont. Prestress
    • Continue load 1
    • add load 2
I found that CNTNLSUB carries over the stresses and strains from previous subcase, but not the load.
Then, if stresses&strains are carried over, but the load starts from scratch, there will be a discontinuity, won't there?
I wonder which combination is correct:
  • Subcase 1
    • Prestress
  • Subcase 2
    • CNTNLSUB(1)
    • Load 1
AND
  • Subcase 3 (I expect a different load path here, becaue Load 1 will start from zero again and will be lineary superimposed to Load 2)
    • CNTNLSUB(1)
    • LOADADD(Load 1, Load 2)
OR
  • Subcase 3 (if the above said is true, then the stresses and (linear) strains from Load 1 will have disappeared at the end of this subcase)
    • CNTNLSUB(2)
    • Load 2
OR
  • Subcase 3 (I expet a discontinuity here, because Load 1 will start from zero again, while the corresponding stresses & strain are carried over)
    • CNTNLSUB(2)
1 - 3 of 31
    User: "RobinsonFerrari"
    Updated by RobinsonFerrari
    Hello Heidkamp,
    If you do your first example (LOADADD), load 1 will not start from zero. You will only add load 2 in this case. So, this should be the right option for your case.
    Please try this in a small deck and let me know if it works for you. Otherwise, attach your deck and I can take a look.
    Thank you,
    OP
    Hello Heidkamp,
    Thank you,
    Hello Mr. Ferrari,
    many thanks for the quick response.
    Just to make sure:
    Do you mean option 1 (CNTNLSUB(1)+LOADADD) or do you mean option 3 (CNTNLSUB(2)+LOADADD)
    Kind regards,
    Arno
    Hello Mr. Ferrari,
    Just to make sure:
    Kind regards,
    Arno
    Hello Arno,
    Subcase 1: pretension = ID_1
    Subcase 2: statsub(pretension=ID_1) + Load1=ID_2
    CNTNLSUB YES or CNTNLSUB=1
    Subcase 3: statsub(pretension=ID_1) + load3=ID_4 => (ID_4=LOADADD for Load1=ID_2 + Load2=ID_3)
    CNTNLSUB YES or CNTNLSUB=2
    PS: In OptiStruct, for continuing to use a load applied in a new subcase that continues from the previous one, you need to re-apply this load, the same for SPC, TEMP, etc.
    Thank you,
    Robinson
