I would like to know how top create a rigid contact between two surfaces that cannot be joined by mesh (node-node) by having different meshes.Example on attached picture.
in OptiStruct it could be FREEZE or TIE contact.
In HyperMesh, you could use Auto-Contact to create these contacts automatically within a search distance.
Ctrl+F >> auto-contact
in OptiStruct it could be FREEZE or TIE contact. In HyperMesh, you could use Auto-Contact to create these contacts automatically within a search distance. Ctrl+F >> auto-contact
Thank you for your answer.Is there any way I could declare manually the surfaces and the contact?
