Effect of AUTOSPC. In what scenarios does AUTOSPC make a difference?
I have experimented with different suspension models with & without AUTOSPC command called and there is no difference in the output results. About 30 SPCs have been added to the system where some of the 1D elements connect to three-dimensional mesh, with 3 degrees of freedom locked out for each, but it’s not made a difference to the result.
What modelling scenarios does AUTOSPC have an affect on the results, and what changes?
An example of a modelling scenario where AUTOSPC changed the results would be very helpful.
Thanks
