Hi everyone,
I have an external flow around this cylindrical pipe, and I want to calculate particle deposition rate on it. What I have tested is to export the particle positions in text file and then calculate in MATLAB, but it looks I can export only position in one direction like x or y or z (No radial position option). What is the best way to calculate it inside the EDEM or export a radial position of particles (Can I add a variable r=sqrt(x^2+y^2+z^2 and then export it in txt file?)
Thank you,
Mahdi.
