Hi
I need to devide a irrgular 2D meshed surface into two surface. If I do not have the geometry, is there any way that I can directly trim the 2D meshed with a plane/surface/line interceded with it?
I would convert it to FE Geometry and then you can use the geometry edit tools.
https://help.altair.com/hwdesktop/hwx/topics/chapter_heads/fegeometry_r.htm?zoom_highlight=fe+geometry
