1]Can we add/remove contact pair in subsequent loadcases 2]Can we add/remove elements in optistruct in two laodcases during topology optimization
Hello Prasad,
For Q1:
You can use MODCHG for that but it is mandatory to run a Nonlinear Static analysis. With this card you can activate/deactivate a contact, group of elements or rigids. You can read more about the application and limitations in our documentation: https://help.altair.com/hwsolvers/os/topics/solvers/os/modchg_bulk_r.htm?zoom_highlight=modchg
Here you can find an example model too: https://help.altair.com/hwsolvers/os/topics/solvers/os/subcase_specific_model_change_using_3_rings_os_example_r.htm?zoom_highlight=model+change
For Q2:
MODCHG works only for contacts during optimization, and not for elements. In this case, you may want to try the Subcase Specific Modeling feature: https://2022.help.altair.com/2022.1/hwsolvers/os/topics/solvers/os/subcase_specific_modeling_r.htm#subcase_specific_modeling_r
Details for the SUBMODEL entry: https://2022.help.altair.com/2022.1/hwsolvers/os/topics/solvers/os/submodel_sub_r.htm
Thanks, Vinicius Gomes
Thank you so much for this information. It will satiate my purpose.
