I have three surfaces need to equivalence. Surface 2 and 3 have already well connected. When I tried to equivalence 1 and 2, the edge between 2 and 3 will b distorted. Is it any way to stitch edge between 1 and 2 by only changing surface 1?
In the stitch tool you can drag edge 1 to edge 2/3.
Those 1 2 and 3 are surfaces. I am not trying to merge edges. In fact. I generate surface 1 by using the upper edge of surface 2 and a line. Why generated surface 1 still shows red color edge?
I think I figured out the issue. If I generate the surface in the the same component, it will genterate greenish edge. If I switch to other component but using the lines in the original component, it will yied red edge and sometimes it is unable to stitch it. Thank you all the same.
