There is plot window that I can create curve using solution data.
But I can't find how to plot this responses.
How can I plot this responses?
You can press the "+" sign on the window:
Then a new window will appear:
If you want stress results you will have to select elements and not nodes.
I hope this helps.
Ioannis Makris
