Greetings!
I'm currently facing an issue in my simulation where the error rate fluctuates drastically from 0% to 99% in an instant, just after the start (run it and you'll see). Despite experimenting with various approaches and having successfully run similar simulations before, I've been struggling with this particular issue for over a week without any progress. While I'm not particularly skilled in Radioss, I'm considering the possibility that the problem might lie in the contact definitions. I did manage to get the simulation to run properly once by adjusting Gapmin, which leads me to question whether it's configured correctly. Though, I've followed the same reasoning as in others with succesful results. Here are the considerations I've made for Gapmin:
- Contact Crash - Barr: The distance between the shell and the closer node of the crashbox.
- Contact Crash - AIP: Half of the combined thickness of each.
- Contact FBH - AIP: Half of the AIP thickness. (FBH is a composite, and theoretically, I've set the surface as the upper layer of the laminate by setting Ipos=3 after reviewing normals).
Any insights or suggestions you might have would be immensely helpful. Thank you in advance!
