Which function in EDEM C++ can add particle body force without including Field?
Or is there any document for EDEM C++?
Hi Qin
You can find the EDEM Programming Guide here: https://help.altair.com/edem/topics/programming_guide/introducing_the_programming_guide_c.htm
For the description on the different functions available with the API, you can find the API documentation in the following location:<EDEM_INSTALLATION_FOLDER>/src/Api/Help/index.html
Hope this helps.
Thanks,Jerrin Job
