I imported a STL file into heypermesh. When I hides all the geometries, nothing shows up. When I uses "From FE" to create surface, I can use displayed elments. I was so confused about what I have imported. Are those elements or geomtries?
STL facets are imported as 'elements' in HM
Once imported, you can build surfaces from the mesh.
