Please help me the below error.
There probably is monitored volume with elements facing inwards, which is invalid.
Use 2D>composites>element normals to display, adjust or reverse elements defining an enclosed volume, so all elements are outward-facing.
There probably is monitored volume with elements facing inwards, which is invalid. Use 2D>composites>element normals to display, adjust or reverse elements defining an enclosed volume, so all elements are outward-facing.
Thank You.. It helped me to solve the issue.
