Greetings,
I am performing a free-size optimization (iteration summary given below) and trying to understand the explanation behind maximum constraint violation %. So far the following is clear:
- If constraint violation > 1% : status is V (violated)
- If constraint violation < 1% : status is A (Active)
- Large constraint violation % could mean that the constraint is too tight and that the problem itself is ill-defined.
- the difference between regular and soft convergence is understood as well
Problem definition: The thickness of an insert is defined to be the DV. Two stress constraints are defined. The objective is a stress minmax formulation.
Question: I am unable to figure out whether the large constraint violation % implies a critical issue. If yes, how does one rectify the problem?
Iteration Subcase Variable Grid/Elem ID Value
0 1 MaxDisp 4712_Y 5.96215e-05
0 0 ObjFun:Min(Max)EQATN 0 4.50698e+07
0 0 MaxConstrViol(%) 0 125.349
1 1 MaxDisp 5566_Y 5.67884e-05
1 0 ObjFun:Min(Max)EQATN 0 3.80622e+07
1 0 MaxConstrViol(%) 0 90.3111
2 1 MaxDisp 5566_Y 5.72058e-05
2 0 ObjFun:Min(Max)EQATN 0 3.54572e+07
2 0 MaxConstrViol(%) 0 77.286
3 1 MaxDisp 5566_Y 5.86367e-05
3 0 ObjFun:Min(Max)EQATN 0 3.52875e+07
3 0 MaxConstrViol(%) 0 76.4375
4 1 MaxDisp 5566_Y 5.95676e-05
4 0 ObjFun:Min(Max)EQATN 0 3.51522e+07
4 0 MaxConstrViol(%) 0 75.7608
5 1 MaxDisp 5566_Y 6.00593e-05
5 0 ObjFun:Min(Max)EQATN 0 3.50283e+07
5 0 MaxConstrViol(%) 0 75.1417
6 1 MaxDisp 5566_Y 6.04046e-05
6 0 ObjFun:Min(Max)EQATN 0 3.49025e+07
6 0 MaxConstrViol(%) 0 74.5125
