Hello. I have a model that is given in their photo. As it is known, the end parts are very small. For this reason, the quality of the mesh is very poor. Do you have a solution to improve the quality of the mesh in the specified parts?
If it is critical to maintain that feature there is not much you can do since the geometry is controlling the mesh quality in this case. Otherwise you can try suppressing some of the lines to see what mesh you get then. Probably not the best option but you could manual move nodes to get the quality you want.
