 I'm currently studying the magnetic behaviour between a rotating N42 magnet and stationary N42 magnets in order to design a nonlinear energy sink. I've managed to run the simulation for the max and min rotating angles of 12.85 and -12.85 degrees respectively. Please see figure below for my setup.
 After I run the solution I get the autogenerated torque deflection curve as seen in the figure below.
 However, when I want to generate the force-deflection curve or any other graph for that matter for the mobile magnet, the resulting curve shows no results and I get this error message.
 Would you able to explain as to you I am getting this message and how to fix the problem?
 Many thanks in advance,
 Sami
