I have a centrifugal force on my component which I realized with a load collector with card image RFORCE.
I tried to do an analysis on it to see the stresses and the displacements applied on this component.
Then I would like to do an optimization of the component using the same loadstep with the centrifugal force but when I run the optimization an error appears which says ' Currently IDRF field in RFORCE is not supported for optimization analysis'.
How can I solve it?
