Hypermesh TCL script to export solver deck
Sebastian Yang
Sebastian Yang Altair Community Member
edited November 2022 in Community Q&A
I am trying to export a model using scripting. What I do is I export it manually and then I check the command.tcl file. But in this case no code was recorded with my action of exporting the solver deck.
Is there any way to record a macro of exporting a solver deck?
This is what I´d like to do with a script:
Welcome!
Best Answer
  • PaulAltair
    PaulAltair
    edited November 2022 Answer ✓
    it should be there in your command.tcl, line should begin:
    *feoutputwithdata
    did you actually click 'export'? it won't be written to command file until you do that
    Anyway, for more information, documentation for the tcl is here:
    feoutputwithdata in hm documentation
  • PaulAltair
    PaulAltair
    *feoutputwithdata
  • Sebastian Yang
    *feoutputwithdata
    Hi Paul,
    Ok, I could find the lines of codes that do the output. It is not in the command.tcl, instead it  is in a file called command1.tcl.  (I also have a command2.tcl...)
    Thanks for the help.
  • Ben Buchanan
    Ben Buchanan
    Hi Paul,
    Yes this is the new way of handling command files.  There is one for each session now.
Welcome!
Welcome!
