I have a spherical mode source created using TICRA grasp software and would like to modify its amplitude and phase offset when using it in FEKO. I defined a spherical mode source in FEKO and tried modifying the scale factor but the far-field plots does not seems to vary with respect to the change in the scale factor.
I have attached the .cfx and .sph (I have changed its extension as .txt) files. Can you let me know why the pattern is insensitive to the magnitude scale factor?
