Hi everybody !
I try to simulate a uniform compressive test with Radioss. I have already do this with law 70 and I succced. But When I use law 33 ( visco_plas) I can't simulate the 'densification region ' : the difference between green et blue curves. Between law 70 et law 33 I keep the same model and I just change properties and material of foam. Thanks in advance for your help. I copy my material law 33 and properties associated. NB: I have blocked with a rigid body and boundary conditions the face without part in contact. The blue part is the impactor , which applies a constant velocity normaly to the face.
