Hello everyone,
I am trying to perform non linear quasi static analysis on the truss problem shown in figure. The constraint is applied on bottom side and compression load is applied on top surface. I am using hyperworks 2019 version optistruct as a solver. Due to compression load, various ligament come into contact with each other and get penetrated. I want to create contact on internal surface of the structure to prevent it. I tried some options but didn't work. I will be really grateful for your kind help.
Note: all the element are 3d brick element created by 'solid map-line drag'. Applied load is 10000 N in -y direction.
