Hi everyone,
I tried to install Hyperworks Student edition after downloading the 'edu2022_win64.exe' which is using 'InstallAnywhere'. InstallAnywhere starts and finishes until the loading bar reaches 100%. After that it is closed suddenly and nothing is continued. As a summary, I couldn't install the HW successfully. My machine's OS is win 10. I suspected from Java and compatibility. I uninstall and reinstall Java. Also, I made the installer exe compatible with older versions of windows and run it as admin. But none of them solved that issue.
I'll be glad if you find a solution for it
