I want to generate reluctance and reluctance torque plots. How will i achieve this using a MACRO AFIR MODEL?
Hi Isiaka,
The macro AFIR can be used for classical postprocessing like BEMF, cogging torque, torque at constante speed. Are you still working on your slotless motor? Reluctance torque is generally computed on motor with slot and with inner magnet, in your case the reluctance torque part should be close to 0
Best regards.
Cyril Favre
Hi Isiaka, The macro AFIR can be used for classical postprocessing like BEMF, cogging torque, torque at constante speed. Are you still working on your slotless motor? Reluctance torque is generally computed on motor with slot and with inner magnet, in your case the reluctance torque part should be close to 0 Best regards. Cyril Favre
Ok, Thanks.
