Is there a way to prevent HM to add "HMprop_" to ELSETs names when i export a .inp ABAQUS file?
Thanks
Hello Julio,
HM_prop prefix is added when the component name and the property name are the same. If you set a different name then it won't be added.
As we recommend now to have ope property per component, I delivered few month a script for creating one property per component, and in the script the property is named with component name. It should be easy to modify the script for adding a suffix or a prefix either to the component or the property to avind this HM_PROP prefix to be added at export.
Hope this helps,
Best Regards,
Michael
