I would like looking for the code to be able to mesh according to the name of the component. For example when I do automatic mesh for the component named 'NIV1_D0700', I got the code in the command.tcl file as below:
*startnotehistorystate {Automesh elements}
*setedgedensitylinkwithaspectratio -1
*elementorder 1
*setusefeatures 3
*createmark elements 1 1-56 3845-3910
*defaultremeshelems 1 0.4 4 4 1 1 1 1 0 0 0 0 2 30
*setusefeatures 0
*endnotehistorystate {Automesh elements}
It gives the ID numbers (red color) and not the name of the component, so I can not copy the code. I would like a line of code as below for example:
*createmark components 3 'NIV1_D0700'
In the same way, when I want to cut a surface by two points 'F11', Hypermesh generates a command with ID (red color) but not with component name. If I have a component with several elements (several id), Can I call only the component to make the cut. I asked the question because every time I corrected the geometric model in another software and import it again, the id of all elements are changed, the codes are no longer valid.
*createnode 20.5 30.15 -13.78 0 19 120268
*createnode 20.5 29.25 -13.78 0 19 66021
*mergehistorystate '' ''
*surfacesplitwithcoords 19 20.5 30.15 -13.78 20.5 29.25 -13.78
Someone can help me?
Thanks in advance,
Best regards,
